This command configures a keychain key hash-algorithm.
| keychain_name | Specifies the name of the keychain. |
| key | Specifies the authentication key entry. |
| key_id | Specifies the unique identifier within a keychain. Range is 1-65535. |
| hash-algorithm | Specifies the hash algorithm to be used for the key. |
| algorithm | Specifies the supported algorithms (default is hmac-sha-256). |
The default algorithm is hmac-sha-256.
Use this command to specify the hash algorithm to be used for the key.
The following command configures the keychain hash algorithm:
configure keychain ospfv3-keys1 key 2 hash-algorithm hmac-sha-512
This command was first available in ExtremeXOS 31.3.
